Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Front Disc Brakes Dragging
Old 02-04-2013, 09:58 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
You might check the pushrod clearance between the booster and the master cylinder to see if it is a bit too tight. With a proportioning valve in the system the pedal pressure could be affecting the front more than the rear, especially if the dragging is minor.
Regards,
Andy
