front disc conversion 65 el camino - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2011, 05:31 PM
defilade's Avatar
2012
can I use the stock distribution block for front disc brake conversion? Or do I need this http://www.inlinetube.com/Prop%20Valves/BLK102.htm car was power drum all the way around with single resevoir master cylinder
Old 10-19-2011, 11:03 AM
ogre's Avatar
the 'Duracell Project'
the link you posted is an original type drum/drum dist block.
you will need a new master cylinder set up for disk/drum and pr100 disk/drum prop valve
Old 10-19-2011, 01:03 PM
For the 1967-70 model years, GM used the drum brake distribution block with a separate external metering valve. These are also available as repros. Either way works fine.
79 El Camino Rear Disc brake conversion Nailhead Suspension - Brakes - Steering 6 12-23-2012 09:22 PM
3/4 Ton Front Disc Conversion...HELP! 31fordcoupe Suspension - Brakes - Steering 3 05-28-2011 07:14 PM
front disc conversion on 51 chevy 3/4 ton 3/4ton flathead Suspension - Brakes - Steering 3 11-11-2010 08:18 PM
Front disc brake conversion Sly's 53 Suburban Suspension - Brakes - Steering 8 10-20-2008 05:24 PM
71 el camino disc brake conversion stu_yoakam Suspension - Brakes - Steering 5 03-19-2007 04:34 PM
