Front Disc Rear Drum Brakes
I have a 76 Monte Carlo with front Disc & Rear Drum brakes. The latest car magazines are big on converting rear drum brakes to disc brakes. If I upgrade to high performance calipers, rotors and pads in the front and high performance shoes in the rear will this be good enough for street driving. My engine produces about 3 times the HP and Tq as the original 305CID. Thanks for the input.
street machine
if it is just a street machine i would just upgrade to good friction material, if you are going to domore than street driving then I would prolly upgrade the fronts to something bigger.
Jesse |
No matter what the HP is, the weight is still the same.
So stopping power would be the same. On the street all you will need is a good quality brake system. Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
| All times are GMT -6. The time now is 05:00 PM. |
