Front disk brake swap. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2011, 01:50 PM
I own a 1978 Buick Reagal W/ 10.5 inch disk brakes. I would like to know if 11 inch disk brakes from a 1986 caprice classic will work. I have the spindles, rotors and callipers from the caprice. Will the steering be affected ? Ifthey will not work is their a disk brake set up from another G.M. make or model that will be compatable ?
Old 11-03-2011, 04:25 PM
The Caprice and the G-body have nearly the same rotors, so this is a worthless swap. The B-body wagons and HD brake cars (police/taxi) have 12" rotors. In either case, swapping the spindles will change steering geometry and induce bump steer. Not clear this is a good thing to do.
Old 11-19-2011, 05:08 PM
Last journal entry: 1955 Chevy Truck
The LS1 swap is really the way to go. Modify your existing spindles, cut down your rotors to create a hub, and mount the LS1 rotors, abutment brakets and adapter bracket and your in business. I did this to my Monte Carlo front brakes, and it worked out awesome. You have to go with 16" wheels at least for the caliper clearance. Listed below is a url address you can see the details, or just Google LS1 G Body brakes and there is lots of good info. Good luck!
http://v8s10.org/forum/viewtopic.php...=17842&start=0
From Drum to disk brake front end? 69chevytime Introduce Yourself 3 08-06-2006 08:26 AM
Front Disk brake conversion HD chopped pickup Suspension - Brakes - Steering 12 02-15-2006 08:07 PM
Put front disk brake on my 1970 parisienne Parisienne70 Suspension - Brakes - Steering 4 12-06-2005 03:55 PM
disk brake swap jellybean Suspension - Brakes - Steering 1 02-12-2004 01:04 AM
disk brake swap CARGUY Suspension - Brakes - Steering 0 07-22-2002 12:52 PM
