Front Disk Brakes on 1970 Nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2009, 07:14 PM
I want to convert a 1970 Nova to front disk brakes, what newer vehicle with front disk brakes will fit on the 1970 Nova if any.
The Following User Says Thank You to Skern For This Useful Post:
pauloswalt (04-04-2013)
Old 05-07-2009, 07:56 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Scroll down maybe they can help. http://chevynova.ca/73nova/references.html . Cole
Old 05-07-2009, 08:21 PM
Very old hotrod but the brakes and spindles on any nova up to 76 should work.Dont foget to get The master Cylinder and proportioning valve for proper brake equalization......
Old 05-07-2009, 09:37 PM
302 Z28's Avatar
My 70 Nova had disc brakes, and it wasn't an SS either.
Vince
Old 05-07-2009, 09:38 PM
ericnova72's Avatar
More for Less Racer
75-79 Nova spindle will not fit as they are front steer with an integral cast steering arm, the same as 70-81 Camaro/Firebird. 69-72 A-body will fit if you swap and reverse the steering arm on the spindle.
Old 05-07-2009, 09:43 PM
ericnova72's Avatar
More for Less Racer
Vince, my 72 non-SS 350/th350 also came from the factory with discs. I was told all 350 cube or larger V8 Novas 1970-up came stock with discs. Lower engines got drums unless optionally ordered with the discs.
Old 05-07-2009, 11:23 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Another note on that model Nova. The original drum brake systems had different rear wheel cylinders than disc. I dont recall it they were larger or smaller but I had to change everything over.
Old 05-08-2009, 09:20 AM
You can't reverse the arms, you need to use the original Nova arms. Also, the only difference between the drum and disk spindles is the height of the boss that the to backing plate bolt goes into. You can machine the drum spindles, get repro caliper brackets on ebay for $25, and buy new calipers and rotors at any auto parts store.
http://www.pozziracing.com/brakes.ht...Drums_to_Discs
Old 05-08-2009, 07:12 PM
Skern 1970 Nova disk Brakes
Thank you for the info, I will be back in the future, you were all very helpful
Old 05-08-2009, 07:36 PM
Hi 2manytoys: 20 years ago I had a 1956 Divco and I restored it. it was complete when I acquired it, so it was an easy restoration. Sold it to a dairy after. you are like me 59 with 2many projects.
Old 05-15-2009, 07:30 PM
NAIRB's Avatar
You just need the brakes off of a 69-72 A body. You'll need to grind the boss down on the spindle where the backing plate bolted onto the spindle down about .615"
You can use a disc brake spindle from a Chevelle of the 69-72 vintage or buy them new$129.00 per pair.
Old 05-17-2009, 09:37 AM
rachet ralph's Avatar
i had a 1968 nova was 6 banger, i used spindles from a 1973 nova to change mine over to disc brakes theres a junk yard close to me has some older cars, i can look see if theres any on them i'm in north carolina, so let me know going there tuesday get some parts so i'll look and post if they do! so you'll know! peace!
Old 05-28-2009, 09:48 AM
Thank you, But I already bought a parts nova with the disk brakes
From Drum to disk brake front end? 69chevytime Introduce Yourself 3 08-06-2006 08:26 AM
Put front disk brake on my 1970 parisienne Parisienne70 Suspension - Brakes - Steering 4 12-06-2005 03:55 PM
disk brakes front 40 chevy B Butcher Introduce Yourself 3 11-18-2005 03:33 PM
early nova disk brake conversion hotrod66_57 Suspension - Brakes - Steering 2 04-29-2005 01:55 AM
1970 GMC Truck Disk brakes digtaz Suspension - Brakes - Steering 20 04-03-2003 09:39 AM
