front driveshaft problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2007, 06:18 PM
i have a th400 with quadratrac tc, and i went to put the front drive shaft in and the caseing to the drivesahft was hitting the side of the transmission. I have seen other th400/qt setups and the transmission housing was busted in the same spot. It is in a j10. Any suggestions. and if not what would be another good setup to run with a 304? thanx
problem installing front sway bar 40 ford. EGOP8 Introduce Yourself 3 03-25-2007 08:05 AM
'40 Ford front axel on a T-bucket Nightfire Suspension - Brakes - Steering 13 07-01-2005 10:46 PM
Please all read... want to start a BIG project knowldgeisfatal Suspension - Brakes - Steering 58 06-29-2005 07:55 AM
dana 44 front axle non hotrod problem. crazy larry Transmission - Rearend 16 04-19-2005 01:47 AM
front end shake brainsboy Suspension - Brakes - Steering 3 02-14-2005 10:30 AM
