Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Front drums with rear discs
Old 12-24-2008, 08:40 PM
matt167 matt167 is online now
Wiki Edits: 31
Originally Posted by joe_padavano
You make it work by selling the front drums and getting disks. Sorry, but front drums/rear disks is a REALLY bad idea. You can use a proportioning valve to really dial back the rear brake pressure, but why bother.
actully, that would not work.. would need to dial back the front preassure, because of the self energization, the brake force on the front would not be balanced with the rear 50/50 like a front drum setup would be with 4 wheel drums... but any way you look at it, it's not a good idea
