Front end 1950 F1 bolt on swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2008, 12:58 PM
Does anyone know of a front end swap that gives IFS to a 1950 F1 that is bolt on and would not require cutting the frame? I either want find this or keep the straight axle and add power steering and disk brakes.
Old 05-24-2008, 02:31 PM
techinspector1's Avatar
Wiki Edits: 326
Here is the result of doing a search for threads on the subject....
http://www.hotrodders.com/forum/sear...archid=1794899
Old 05-25-2008, 07:19 AM
Gabbyp's Avatar
Chassis Engineering makes a bolt in unit for the 1950 F1.
http://www.chassisengineeringinc.com\
Front end swap for a 50 willys wagon gmwillys Suspension - Brakes - Steering 1 12-08-2006 10:21 AM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
front end swap fedexman Introduce Yourself 2 07-21-2004 10:47 AM
