front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2011, 02:50 PM
front end
62 nova. Front end gets out of shape on uneven road surfaces. I jack up car on one side the wheel turns in but other side doesn't turn out,s it just the geometry?
Old 06-10-2011, 08:17 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Are all the front end components in good shape? Tie-rods, idler arm etc?
Andy
Old 06-10-2011, 05:02 PM
chevy 11 front end.
I know from previous experience that they are not really stable, i had new convert. in 63. This is almost dangerous, two front shops say all is well,NOT. Thinking rack and pinion kit way to go.
Old 06-13-2011, 02:34 PM
slow4dr's Avatar
The early nova clips have some pretty terrible geometry from the factory. CPP & CBR make tubular control arms but only the CBR pieces actually address the camber issues. An aftermarket rack & pinion is the next logical step to help correct bump steer.
Between those two items you'll quickly be approaching the cost of a complete replacement clip.
-J
Old 06-14-2011, 09:02 AM
57halfton's Avatar
My first guess would be the idler arm. 62 Nova's had a very poorly designed idler arm that was redesigned for 63 to 67 Novas. Check Steves Nova site for info on how to upgrade your idler arm , try that before you start spending good money on expensive aftermarket parts.
34 Ford chassis w/MII front end - front tires rub heyjude076 General Rodding Tech 4 04-09-2009 08:46 PM
Front frame / Front crossmember blueprints - feedback needed lowROLLERchevy Suspension - Brakes - Steering 2 09-20-2008 06:46 PM
making front drum into front disc.....? barbiekiller Suspension - Brakes - Steering 3 05-01-2007 06:57 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 11:12 PM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 02:45 PM
