Front End Alignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2007, 12:55 PM
Front End Alignment
I a looking for a simple way to align the IFS on my Model A. Can anyone direct me to a source of information concerning this?
Old 01-23-2007, 01:23 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I took mine to a front end alignment shop. They aligned all four wheels.
Old 01-23-2007, 02:13 PM
60tbirdrick's Avatar
Sacred Steel
Last journal entry: The dash
Speedway Motors has a nice caster/camber gauge.
http://www.speedwaymotors.com/p/2698...?itemNo=CASTER
I have one for my T-bird. The main reason I use this is because my car sits so low that I don't think it will make it up on the alignment rack without scraping the bottom. Works good, easy to use and all you need is a flat level surface.
Cheyenne to Silverado Front end ok4ayl Electrical 3 11-09-2008 08:51 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 07:03 PM
455/new front end? Meka Engine 4 03-24-2004 06:17 PM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 05:33 PM
