Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #16
Old 05-09-2008, 04:04 PM
fatboyman05 fatboyman05 is offline
re: Front-End Alignment/Rear Axle Offset
I would check the rear axle to be sure it is square to the frame (and that the frame is square) and that the axle tubes are totally staight. I had a truck once that had a bent axle tube and I didnt "feel" it when driving but tire wear was an issue over the long term....
Old 05-10-2008, 04:05 AM
Sweet-34's Avatar
Sweet-34 Sweet-34 is offline
Lost In The 50's
Update!!!!
OK!!!! I did all the measuring and the offset and wheelbase are both fine and the frame is square. I found a local shop that is run by a gearhead and we are going to play with the Caster and Camber to get it to run down the road straight.
I'll put up a post when we get the end results. Thanks to all for your help.~-34
Old 05-15-2008, 07:49 AM
Sweet-34's Avatar
Lost In The 50's
Got It Right!!!!
Just got back from the alignment shop. They had an old boy that worked on these old cars for years. The Caster was waaaaay Negative on the left side (driver) and after setting everything up right--------the car goes down the road straight as a string. You can take your hands off the steering wheel and it just keeps on going and going and going!!!! Thanks to all for their input~~~~~Ron
Old 05-15-2008, 10:03 AM
F&J F&J is offline
So,you going to sit around talking..or you gonna go drive it
Ooops, gas went up about 50 cents since you had the problem
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Front-End Alignment/Rear Axle Offset"
this is a saver.... GM build codes TooMany2count General Rodding Tech 22 03-08-2008 06:00 PM
How do I identify a GM front end? hotred86 Suspension - Brakes - Steering 2 03-25-2007 11:05 AM
36 chevy front end oldrodder43 Suspension - Brakes - Steering 2 10-09-2006 04:52 PM
7 and 5/8 rear end drivers side axle leaks fumplet Transmission - Rearend 7 03-02-2006 12:39 AM
34 ford truck front axle ideas and questions lilred34truck Suspension - Brakes - Steering 1 10-30-2002 04:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
