Front end alignment: When is "close enough", enough? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2009, 11:06 PM
scrot's Avatar
hello, I replaced one front strut on my '87 Ciera because it was leaking oil and rattling.
When I was removing it, I diligently lightly scratched aligment marks on the bolt head of the eccentric washer, the washer itself, and the part of the strut next to the washer. I installed the eccentric washer into the new strut and tried to line up all the alignment marks, but DUH, I couldn't since the matching marks was on the old strut which was sitting in the trash pile.
I remembered where the scratch marks were pointing (in the 2 o'clock position), so that is where I adjusted the eccentric washer to.
I drove it and the car doesn't pull and feels fine.
Do you think I got the alignment so close that it wont wear out the tires any? I'd rather not bother to go to the alignment shop.
Thanks.
Old 08-28-2009, 11:13 PM
Wiki Edits: 31
unfortunatly no.. caster and camber are likely out. but a road test would only pull if the toe was out. because if caster and camber are pulled equally, you would never tell, as the caster corrects the camber imbalance....
easy enough to check/ change yourself. caster/camber gauges are only about $40
Old 08-29-2009, 04:35 PM
scrot's Avatar
Ok Thanks. So do you think I can make the adjustments using one of those gauges?
Old 08-29-2009, 05:03 PM
Wiki Edits: 31
the 1 gauge checks both angles.. your toe is still ok, as it was untouched...
Old 08-29-2009, 06:40 PM
an easy way to check toe is get a string or tape measure and have the same distance on the front and the back of the tires. Measure across edge or center (which ever is easiest to reach/duplicate readings) of tire to the same spot on the other tire.
( ) ( ) same distance
You you really want to align the car. build a "box" out of string. measure top to bottom for camber and left to right for toe. Just remember when adjusting alignment caster, camber, then toe or you will through the other out of spec.
frustrating front end! 55shoebox Suspension - Brakes - Steering 7 10-10-2007 12:46 PM
Camaro front end swap help Augusto Suspension - Brakes - Steering 9 09-28-2007 09:17 PM
front end problems tonylsg Suspension - Brakes - Steering 13 04-15-2003 07:47 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 08:10 PM
front end alignment specs drag racing snakejake Suspension - Brakes - Steering 3 04-27-2002 12:05 AM
