Front end geomerty - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2017, 11:47 AM
Front end geomerty
I have a fiberglass 1932 3 window coupe with 350 SB and 9 inch rear end. It likes to wander a bit at 40mph and up. I set the toe in at 1/4".
I would like to know what a degree of pos. caster I should try to bring it under control.
You can drive it at 70mph but you have to be steering all the time. I also have adjusted the steering gear.
I would appreciate any help on this THANK YOU diesel doc
Old 03-20-2017, 11:54 AM
astroracer's Avatar
Shoot for 5 to 7 degrees. That will get the caster trail to a point where the wheels will self-center.
Mark
The Following User Says Thank You to astroracer For This Useful Post:
techinspector1 (03-20-2017)
Old 03-20-2017, 12:06 PM
techinspector1's Avatar
Wiki Edits: 326
Next time you build a rod, use IFS and prevent all that monkey motion. Straight axle technology is 100+ years old.
The Following User Says Thank You to techinspector1 For This Useful Post:
PHWOARchild (03-27-2017)
Old 03-20-2017, 03:41 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I'd try 1/4 toe out and see what happens.
Toe out will typically make it more stable at speed and gives and indication of where to fix the problem.
Old 03-20-2017, 05:45 PM
Wiki Edits: 326
Try airing up the tires all around and see what happens.
Old 03-20-2017, 06:52 PM
39 master's Avatar
Solid axle
I'm with Astroracer, lay the kingpins back 7 degrees. I also assume you are using a Vega box. Check every tie rod and the box for any play. I've heard nothing but good reports on the Unisteer half rack to replace a worn out vega box. I've had three solid axle cars and when properly set up worked as well as any front end AND it"s strong.
Old 03-21-2017, 08:39 AM
454 Rattler's Avatar
NEVER SATISFIED !!
I guess I missed it or something. What suspension do you have ? Is it a straight axle or independent suspension ?
454 RATTLER
Old 03-21-2017, 08:52 AM
THANK's for the info!
I will try 7degree Pos., and the 1/4 toe out I don't know about that. I have checked every thing for play and nothing there, it's all tight.
As far as (IFS) I have not a clue what that is and there is no rag joint.
I will let you know how the toe out works.
THANKS AGAIN for the help
Old 03-21-2017, 03:13 PM
It's a straight axel with a cross spring with steering gear mount on left and drag link crossing to right with the tie rod in front of the drag link
Old 03-21-2017, 04:57 PM
39 master's Avatar
Sounds like your belly button solid axle front end. If you take it to a front end shop the only thing they can set is the caster (lay the kingpins back) and the toe. Camber would have to be set by bending the axle and unless you ran into something BIG the axle should not be bent. So, bottom line is to set the kingpins back with the upper and lower 4 bars or hairpins (whichever you have) then take it to a shop for the toe. I like to have mine set at 1/16 to 1/8 IN not out but that's up to you and the shop. Note that I said take it to a shop for the toe because I just can't get that close at home. Warning, it's a bit tricky messing with the 4 bars or hairpins...be careful.
Old 03-21-2017, 04:58 PM
Fasto44's Avatar
Last journal entry: Old Shop Truck - '56 F-100
Do you have a panard bar that runs from the chassis to the opposite side of the front axle mounted to the bat wing? Without one of these the cross steering with pull and push the axle back and forth which leads to wander. My blown '34 had the same problem until I added a front panard...fixed the problem. BTW I was only running 1/8" toe in on each side (1/4" total).
Old 03-21-2017, 06:57 PM
39 master's Avatar
front end
Good point Fasto. Some run a dead perch in place of one of the shackles instead of the panhard bar.
Old 03-22-2017, 06:07 PM
1/4" toe in, or toe out is way to much. The original recommendation for that front end was 5 to 7 degrees caster, and 1/8" toe in, and that was with bias ply tires.
Radial tires do not need that much toe in, as the radial tires tend to run straighter than bias ply tires. Also unless the traction is exactly equal on both sides, the front end will tend to follow the the tire with the most traction with excessive toe in. When the traction changes, the front end will change side as to the dominant tire, and go off the other way. Setting the toe it to 1/16" or less seems to be the way to go, even to the point of very slightly toeing the tires out.
This is not just my experience with one car, I have built a bunch of cars, and trouble shot many more.
Old 03-23-2017, 06:21 AM
front end geometry
my car works best with 7` caster and 1/4" toe out with radial tires set at 30psi front and rear. 6" drop tube axle with corvair steering box. car shows no excessive wear on front tires. I drive the car on average of 4000 miles a year. make sure front and rear are square with each other
Old 03-27-2017, 11:15 AM
Dclifton32's Avatar
I set my king pin's to 7deg's what a difference, car tracks down the road.
front end alignment for 79 t-bird Heidts front sus jenajean Suspension - Brakes - Steering 4 09-16-2014 08:58 AM
1953 Buick Special-front end rear end?? mbjeep Suspension - Brakes - Steering 8 12-06-2009 06:32 PM
34 Ford chassis w/MII front end - front tires rub heyjude076 General Rodding Tech 4 04-09-2009 07:46 PM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 01:45 PM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 05:33 PM
