front end lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2013, 06:48 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
front end lift
I have a fatman MII front suspension with stock control arms and strut rod. It gives the truck more rake than I like. Any easy way to lift front end a couple of inches?
thanks
Old 06-19-2013, 07:57 AM
Wiki Edits: 27
spring chart.
When I was an engineer at Ford I had the Front spring engineering chart. There were 11 different springs for the Mustang II-pinto suspension. The chart had all the info on the springs, Rate , free length, ride height of completed vehicle with various options, etc. There was only about 2 inches of ride height variations. You could order new springs from one of the vendors..I was giving advice to a kid that worked on the assembly line and raced a pinto in what I think was Called Mini Stock , on road race courses.
Old 06-19-2013, 08:15 AM
Hwyhogg's Avatar
Thanks...I should add I used mustang springs for an early 90s model, per fat man, I cut one coil. They recommended the V8 spring since I have a 460 engine. I also understand the lower control arms should sit level--which they do. Btw, love the improved ride compared to straight axle, again it lowered the front more than I like. On another note, if I could do it again, I would get new leaf springs, power steering and stay with the dropped axle.
Old 06-19-2013, 10:51 AM
ogre's Avatar
the 'Duracell Project'
the lower A arm should be level at ride height, installing a longer spring would mess up your steering geometry
check to see that you do not have drop spindles
Old 06-19-2013, 04:00 PM
sedanbob's Avatar
Ogre's got it right. If you don't have dropped spindles, the only simple thing left is a taller wheel/tire combo.
Old 06-19-2013, 09:02 PM
Hwyhogg's Avatar
no dropped spindles...they are stock...guess I'll live with it...I don't want to put taller wheels on the front only. Thanks guys, maybe have to c notch and lower rear.....
Old 06-20-2013, 06:38 PM
ogre's Avatar
that goes without saying.
what are you working on?
Old 06-24-2013, 04:31 AM
Hwyhogg's Avatar
56 ford panel truck...pics in my journal
Old 06-24-2013, 07:26 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Why not try the same springs as before, w/o cutting a coil?
You could consider dropping the rear ride height as well...
Old 06-26-2013, 09:34 AM
Hwyhogg's Avatar
Well, I assumed they recommended cutting the coil to get control arms level. I most likely will drop the rear to get more level. Rake is cool for a muscle car, but looks kinda lame on a panel truck....live and learn
Old 06-26-2013, 06:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My take on it is cutting off one coil isn't gonna change the geometry enough to really matter, and there's the possibility it was recommended for stance as much as anything- but asking them what the results would be in your case by leaving the spring uncut could be revealing.
51 Ford Truck Front Tilt Lift sandidande Body - Exterior 2 02-06-2007 07:54 AM
Front end lift 66 cuda street rodder 1937 Suspension - Brakes - Steering 1 05-06-2004 08:46 AM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 02:45 PM
How much Torque need to lift front end? unstable Engine 22 02-20-2003 10:54 AM
front suspenion lift crazy4x4fanatic Suspension - Brakes - Steering 0 01-29-2003 12:05 PM
