Front End making cracking noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2002, 07:27 AM
Post Front End making cracking noise
I just put a new sway bar in but it seems when my van is either stopping or starting some thing always cracks. Or thats what it sounds like. Its like a loud clunk. It also does that when I am stopped and I turn the wheels back and forth. Its going clunk clunk clunk. What can be wrong and could it be serious???Thanks Guys
Old 11-05-2002, 08:33 AM
Post
check the calipar mounts , upper and lower ball joints or even the steering box. I have seen all of these make popping noise in the front end and all can be a danger to the driver as well as others.
The best thing to do if you are not a front end man is take it somewhere for a free inspection.
Old 11-05-2002, 01:21 PM
New Member
Post
If youve had the springs out recently check theyre seated in the A Arms correctly to
Cheers
Dale.
Old 11-05-2002, 07:22 PM
4 Jaw Chuck's Avatar
Post
Sounds like a broken sway bar link bolt, you did replace them with the new bar right?!
— Han Solo
Old 11-05-2002, 08:11 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
If it's a ford, check the radial control arm bushings (the part that goes back from the axle and ties to the frame the bushing is on the frame end) If not, what kind of van is it?
Old 11-11-2002, 03:23 AM
aka Duke of URL
Exclamation
Certain year FORD vans experienced cracked crossmembers.
Need to know make and year.
