Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - front end problems
Old 04-14-2003, 04:12 PM
tonylsg's Avatar
tonylsg tonylsg is offline
Post
thanks PrimeMover, I did take it to a front end shop this past weekend and he could not see anything wrong. I took it home and looked under it today and the strut rod bushings are definantly bad. about a 1/4 inch between back bushing and frame when car has moved forward due to excessive outward toe and just the opposite when car is rolling backwards. I will replace those tomorrow and see what happens. If this does not fix it I will start replacing control arm bushings because I do know that the tie rod ends and upper and lower ball joints are good. If that does not fix it then I have no idea.
Thanks for the help,
Tony
