Front End Rebuild.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2010, 04:52 PM
66Moostang's Avatar
Front End Rebuild..
I am planning on doing a front end rebuild on a '67 Cougar and want to know what parts I should replace. I have seen kits for more than $400 but also smaller kits for less than $200 and want to know what to look for and what is most important to replace.
Im trying to save as much money as I can and this car is only a daily driver with a stock 302 and C4 automatic. I found a kit for $200 that has the ball joints, lower control arms, and tie rods but if there are other important parts to replace maybe I should look into a more complete kit.
Old 07-22-2010, 05:39 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Hmm, maybe anything that rattles....
Add upper and lower control arm bushings, and check all of the tie rod ends, steering components, basically anthing that moves with the suspension for wear.
Semper Fi
Camaro front end swap help Augusto Suspension - Brakes - Steering 9 09-28-2007 08:17 PM
1951 Ford f1 front end n00b Suspension - Brakes - Steering 5 09-09-2007 09:48 PM
1965 Impala Front End Suspension Problem EazyDuzIt102 Suspension - Brakes - Steering 2 03-29-2004 05:52 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
front end rebuild kits crshrmn3 Suspension - Brakes - Steering 1 12-16-2002 04:04 PM
