front end set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2007, 09:08 PM
front end set up
got a question.
which is the better frontend setup to use on a ratrod: suside or conventional with a front crossmember?
Old 08-15-2007, 12:09 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
One is not better than another. It all depends on the look you want. Do you want your tires out in front of the grille or even with it. The suicide front suspension with the spring perch mounted above the front crossmember will allow you to get the frame down lower in the front than one with a spring mounted under the crossmember unless you Z or pie cut the front frame rails.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Chevy truck Tilt front End! Onestophotrodshop Body - Exterior 0 12-01-2005 11:26 AM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 07:03 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 07:10 PM
raise the front end of the Chevelle tetzlaff Suspension - Brakes - Steering 3 09-19-2002 10:22 AM
