Front end shimmy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2006, 03:50 PM
Front end shimmy
My 1935 has a all new Mustang II front with new Michelins (been sitting off car for years). Had balanced by Pat Goss' Garage on their trick machine and aligned by front end shop with excellent rep. On occasion, about 50% of time if I let go of wheel will get slight shimmy that goes away when I regrab wheel. Don't feel much when holding wheel. Any suggestions?
Old 07-25-2006, 09:53 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Try driving on a freshly paved road & see if it still happens.
Check to make sure everything is tight {tie rod ends. ball joints Ect...} check the wheel bearings.
If it still does go get a load force variant balance to see it the wheel(s) is some how screwed up.
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 07-25-2006, 10:23 AM
Thanks I did notice last night that the tie rod ends don't have cinch nuts but I can't imagine the tie rod ends moving that much but anythings possible. I just hope I can maintain the toe in adjustment when I unscrew to put on the nuts.
Old 07-25-2006, 10:45 AM
gdubstub's Avatar
Old Crusty Streetrodder
You mentioned that you have an all new MII front end. Check the lower control arms and make sure they are parallel to the ground when at rest. If not, you may be experiencing bump steer, which can be confused with tire balance shimmy and general steering shimmy. Some can be adjusted (Chassis Engineering) and other not (Heidts).
Old 07-25-2006, 11:43 AM
It's a Heidts. I put it in according to instructions and the lower arms arms are parallel to the road. If it was off, couldn't one change the spring height to raise or lower the arms? It drives perfect except for this slight shimmy. I think your right that the type of road surface affect the amount of shimmy. On some roads there is none.
Old 07-26-2006, 07:15 AM
gdubstub's Avatar
You can always adjust by changing the spring height, but Chassis Engineering has an adjustment at the top of the tower for setting ride height.
If your lower control arms are parallel, you're fine...it's something else
George
Old 07-26-2006, 07:56 AM
Thanks. I drove it last night and was fine on certain roads. I'm thinking it's the balance on the tire except it doesn't get worse at speed and at 65 I feel a slight something, but not really shaking, in the wheel but the mirrors are all rock solid. I think first step is to double check balance. I bought the front Michelins new 10 years ago but they basically sat on the car. Maybe they took a set although that should show up on that high dollar Hunter balancer.
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 07:03 PM
Got 39 Poncho, have front end questions rwruther Suspension - Brakes - Steering 0 05-23-2004 02:32 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 07:10 PM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 05:33 PM
