Front end suspention - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2006, 03:02 PM
I have a 69 chevy longbed pickup. I have a set of 20s on it, I need to know what year model trucks can I go to the salvage yard and get the front end off of that has disk brakes and has a 6on 5 1/2 lug pattern. I was told by afriend that 73-87 pick ups will fit. I really don't want to change to 5 lug because I will have to change the rear end also. I need some advise!
Old 08-07-2006, 04:25 PM
It is my understanding that you can just switch the axle shafts and brake drums ... and retain the original rear end ...
Old 08-07-2006, 10:32 PM
Chevy went to a wider rear end (longer axles) sometime during the '70 model year, so that might not work. Might post at www.67-72chevytrucks.com/vboard and see what you find out.
Early Classic Entreprises sells a 6-lug disc conversion for '69 trucks, but it ain't cheap.
Old 08-08-2006, 06:31 AM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
front end suspension
I have had a few of those trucks(still do),but to my knowledge,you wont find a disc brake front end with the 6 lug pattern. When they went to discs they changed to the 5 lug wheels. This has been discussed here before maybe if you do a search you can find it.
Old 08-08-2006, 07:01 AM
Will I ever get it done?
Last journal entry: Hood
IIRC, 39 Chevy is 100% correct. However, with today's CNC machining, you can probably get what you need made. Won't be for salvage yard prices though. I would start by contacting some of the performance brake companies direct and talking with them. Wilwood and the like.
Chevy truck Tilt front End! Onestophotrodshop Body - Exterior 0 12-01-2005 12:26 PM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 08:03 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 05:08 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 08:10 PM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 06:33 PM
