Front end vibrates with acceleration
I know this is not a hotrod, but I've posted questions in the past (long time ago) and it seemed to be alright.
'98 Subaru Forrester AWD This started about 5 minutes into my ride home from work tonight, went on for about 15 minutes, stopped for 5 or 10, then started again, etc... When I accelerate, the front end starts vibrating, the more I hit the gas, the more vibration. When I take my foot off the gas, it stops, regardless of what speed I'm going. SideNote: about 2 weeks ago I got my oil changed and tires rotated at a Quick Lube joint, and I've noticed a slight pull to the right since then. Have no idea if that could be related, but thought I'd mention it just in case. I realize I'll have to take this in to my mechanic, my question is, can I drive it to work tomorrow without doing further damage to whatever it is. If the symptoms are too vague for an answer, I understand. Just thought I'd throw it out there, as boss is NOT going to be happy with me if I call in tomorrow. Thanks in advance for any info. -Laura |
bad tire, or they knocked your allignment somehow.
get a new tire quick, when that stuff happens, most of the time it's a seperated belt which will find its way thru the tire eventully |
I'd be a Happy Camper if that's all it is....
I also have this question posted on the Auto discussion forum of Craigslist. Someone just replied that since the vibrating is happening ONLY while I'm accelerating, that it cannot be tire related. Their reasoning is that the tire is still spinning when I'm not accelerating, therefore the vibration would continue after I took my foot off the gas. He says my transmission is probably shot.
Please, say it ain't so. I'm sick thinking about it. I've only had the thing 3 months, single mom, can't afford a new tranny. =( Thanks for the input, I appreciate it greatly. |
torque can play that effect on a tire that is bad.. it's AWD, so it'll do it regardless of the front or rear... it's a bad tire, I'd almost gaurentee it.
Oh, I could KISS you! lol...
That makes me feel a lot better. I don't know much about cars, but his reasoning made enough sense that I was feeling pretty doomed.
I don't know what torque is, but you obviously do, and it sounds good to me!! I'll get the tires checked out asap. Thank you SOOOO much. -Laura |
My first thought is a bad tire...slipped belt. Second thought is cv joint going bad.
Thanks alot.....
I decided to skip work and err on the side of caution. I will take it somewhere and have the tires checked out.
Funny, I just took it out for about a ten minute drive, nothing. Whatever it is seems to come and go. I appreciate all the input, you guys are great. I hadn't been to this site in a long time. Not sure what made me think of it last night, but I'm glad I did. -Laura |
ahhh... I wondered about that
Is that something that can be seen w/o taking off the tires? I was thinking about swinging it by a friends house so he could confirm or rule that out, but if it's a pain in the butt to get to, I 'll just take it straight on to the mechanic.
My mechanic HATES Subarus and does what he can to avoid them, so I'm guessing he may have to order the part. If I could give him the heads up a day ahead that would be helpful. Thanks again, and I will come back and let you know the outcome. -Laura |
A quick test is to jack up the front end so one of the front tires is off the ground. With the transmission in gear, try to rotate the wheel forward/backward to gauge how much slop exists. If there is slop (wheel rotates more than a half-inch or so), or if you hear clicking noise, then the CV joint is probably bad. Could be a bearing too. Test each side.
Hope this helps. Antny |
Taking it in
I realized last night that I have no jack or lug-wrench. I bought this from my parents so I never thought to check...the same parents who have nagged me for years about having the proper equipment in my car, lol..
Anyway, I just got off the phone w/ my mechanic. I'm going to bring it in this afternoon and he'll check the CV joint to see if it's bad. He did say something about not liking to do the CV joint w/o doing(replacing?) the axle. Would this make sense. I have no reason to dispute what he says as he's always been fair with me, a pretty decent guy. Just wondering what your thoughts on that were. Thanks again, I sure appreciate all the insight! -Laura |
Antny |
Best of luck finding/fixing your car ! |
| 1934 chevy 1/2 front end | lohi | Suspension - Brakes - Steering | 5 | 08-31-2007 11:53 AM |
| Front end mock up shows some problems, cut n weld or frame shop? | Ripped | Body - Exterior | 9 | 11-26-2005 07:03 PM |
| front end problems | tonylsg | Suspension - Brakes - Steering | 13 | 04-15-2003 06:47 PM |
| Mustang II front end Question | horvath | Suspension - Brakes - Steering | 35 | 03-02-2003 04:08 PM |
| is there any front end alignment people out there? | IHAVECHEVYPARTS | Suspension - Brakes - Steering | 5 | 11-26-2002 07:10 PM |
