Front end weight/ spring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2006, 03:08 PM
I am rebuilding teh front end of my 1970 Nova and thinking about buying Moroso trick front springs. The problem is right now there is no engine or trans in the car and I am supposed to know the front end weight before ordering...is there anyway to figure this out...an estimate. The car will have a 350 in it.
Old 08-18-2006, 06:46 AM
Unless it's a drag car, I wouldn't use Moroso springs. I put their light springs in my big block Nova and it sat two inches higher than stock. Had a cut them down. They do work good for drag racing.
Bob
Old 08-18-2006, 08:03 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Spring rate and spring height are completely different.
Old 08-18-2006, 04:35 PM
37 plymouth coupe's Avatar
front springs
From and OLD retired auto parts man....go to a good auto parts store (preferrable one that sell Moog parts) and look up the stock springs for your Nova. Check the "specs" section of the catalog and note the height and rate for the stock springs. Next, cross check the application by part number. Many times the same spring is used on other models (besides the Nova). Once you find a similar vehicle that uses the same spring, see if that vehicle had a V8 option, and get a set of springs for the V8, or go back to the specs book and find a set of springs that are the proper diameter/height, but with a load rated for a V8...Should be a good starting point. (MOOG is not the only company that has good cross references, I am just familiar with their books)...Good luck.
P.S. I have used this system many times in setting up my oval track racers.
Old 08-20-2006, 12:54 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I recommend sticking with the stock spriings until the car is finished and you can determine the ride height and the spring rating desired.
http://www.snopes.com/politics/soapbox/lamm.asp
Old 08-21-2006, 07:25 AM
cboy's Avatar
Last journal entry: Finished
Unless you are doing extensive mods on the body and chassis, the front end weight should be the stock weight (with the stock engine) plus the weight of your 350 and trans, minus the weight of you stock engine and trans (these weights can all be found with a web search). The drawback to this method is if you do not know what engine was originally in your vehicle - which might be your situation.
In any event, I think your best bet is to follow xntrik's recommendation of simply putting the car together with the existing springs...you may not need to alter them at all.
Always learning...and sharing what I've learned.
1952 Dodge Pickup Front End fordson Introduce Yourself 2 01-21-2006 07:39 PM
Chevy truck Tilt front End! Onestophotrodshop Body - Exterior 0 12-01-2005 11:26 AM
Front End Measurements iaclmac Suspension - Brakes - Steering 1 08-03-2004 09:27 AM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 01:45 PM
rear end/ leaf spring question chris1950 Transmission - Rearend 5 07-30-2002 10:19 AM
