Front end welded in.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2003, 08:18 PM
Post Front end welded in....
Well after months of let downs, I finally got my Mustang II front end welded in. The best part is, except for the welding and fabrication of the metal, I got to do it. But now that it is welded in I am lacking the directions to put all the parts that are in my basement in the metal frame. Are there any good sites that list the info for installing the parts? Thanks Steve.
At this rate the 41 Buick might see the road by next year, I hope.
Old 06-13-2003, 02:56 PM
53vicky's Avatar
Mustang II
Is your front end a kit from somewhere like Fatmanfabs?
If it is a mustang II would a regular mustang manual show what you need?
I installed my MII but it was a kit from Fatmans and was fairly simple to do.
Old 06-13-2003, 08:36 PM
woodz428's Avatar
Troll Hunter
Arrow
53vicky is probably right, in that a stock MII manual should get you set up. If it has a full lower A-arm instead of the single factory type it should be a little easier.
