front end "wobble" - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2014, 03:35 PM
31ROC's Avatar
front end "wobble"
Cant figure this one out.....I get a front end "wobble" at same speed....front wheels/tires have been balanced twice and have come out perfect. I have the leaf spring front end...SuperSlide, and unisteer steering set-up. I installed a set of the little chrome shocks, thought it could be those? Almost feels like a motor vibration up thru the steering column, but after swapping with new motor, I get same thing....I doubted the driveshaft being out of balance, since I thought that would not affect front end wobble???
Could it be these shocks aren't strong enough to hold the car down to the road?
Front end/car only has but 3600 miles on it....
Old 06-09-2014, 04:25 PM
Banned
have you hit any pot holes, bumps etc. i am thinking more like spindles , wheel bearings , rotors. have you gotten on it and maybe tweaked the frame.
Old 06-09-2014, 04:30 PM
31ROC's Avatar
No hammering, as the new motor only has about 3 hrs on it, no potholes or bumps to speak of....maybe should pull the rotors and check for run-out? I suppose I could just change out the wheels bearings even though they have minimal miles....I feel it at about between 35-40 mph, maybe up to 45 mph, they seems to smooth out at a higher speed. One other thing, SEEMS as though it is amplified at those speeds when hitting a bump in the road?
Old 06-09-2014, 05:35 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
How much castor are you running..?? we shoot for 5-7 degrees with those kind of front axles.. Since the car has all new parts that eliminates a lot of the culprits as shimmy typically shows up with worn steering parts..try about an 1/8 of toe as well..
Sam
Old 06-09-2014, 06:31 PM
31ROC's Avatar
Sam
you may have something there.....I bought car as a roller, and have no clue if car is set up correctly. I did in the past ask around if anyone locally could do an alignment with no luck. I wouldn't know a thing about caster/camber or toe....is there something that could be done at home in the garage?
Old 06-09-2014, 06:42 PM
Last journal entry: New Rev wheels and BFG KDW II tires
Yes you can do it yourself at home. You just need a caster camber gauge. A few different companies make them at varying prices. Not super cheap but can easily pay for themselves after a couple uses.
It's best to have a turn plate to check the 20 degrees when you turn the wheels. They can be made fairly easy with a couple of steel or aluminum plates and some grease between the two to make them slide easily.
Caster / Camber Gauge w/ Magnetic Adapter
Instructions
Digital gauge.
http://www.longacreracing.com/produc...Level%E2%84%A2
Old 06-09-2014, 08:12 PM
Wiki Edits: 3
this is the one I have..... works for me
Economy Caster/Camber Gauge - Speedway Motors, America's Oldest Speed Shop
Check and see if all the fasteners in the front end are tight and properly torqued.. If you did not build the car all that needs to be gone over to see that it is all good..
Sam
Old 06-10-2014, 04:24 AM
31ROC's Avatar
I will check into this gage. All fasteners have been gone over and tightened and torqued.
Thanks
Old 06-10-2014, 12:16 PM
delawarebill's Avatar
shimmy
also check the toe in.. about 1/8" with a drop axle. what kind of wheels u running. if they are weld's and have that loose spacer inside ????? if so u have 2 choices.. pull wheel & center all lug openings and use a split pin to keep floating center from moving then get them balanced.. drill small hole on back side and install split pin.. or pull rotors, attach wheel get the whole thing balanced.. mark a lug to put back on exactly how came off.. those floating centers are a major pain..
Old 06-10-2014, 12:26 PM
techinspector1's Avatar
Wiki Edits: 326
Here's a pretty good article on straight axle frontends, should help those who are unfamiliar with them....
Solid-Axle Suspension - History & Technical Specs - Rod and Custom Magazine
Old 06-10-2014, 02:39 PM
31ROC's Avatar
wheels are American Racing torq thrust style.
Old 06-10-2014, 11:18 PM
Wheels
What type of lug nuts? Are they tapered seats or the straight type with large washer?
Old 06-11-2014, 03:26 AM
31ROC's Avatar
tapered seats, but I has same issues with chrome reverse wheels,,,,
Old 06-11-2014, 09:19 AM
I have had this type of problem before. One of the things that I found very useful was put a sanding drum (coarse) in my drill motor and then jack up one wheel at a time and spin it with the sanding drum. This will show you any type of tire issue or mounting issue.
Old 06-11-2014, 09:39 AM
31ROC's Avatar
Kind of a neat idea....however, as I mentioned previously, I had same issue with other tires, and other wheels....
Front end alignment: When is "close enough", enough? scrot Suspension - Brakes - Steering 4 08-29-2009 05:40 PM
"soft" front end oldguy829 Suspension - Brakes - Steering 9 12-19-2007 02:43 PM
89 Durango front-end "bounce" Roddin Rob Suspension - Brakes - Steering 3 07-10-2005 04:22 PM
"Serious Suspension" bolt on front end jayjayjamez Suspension - Brakes - Steering 6 09-01-2004 10:29 AM
"T" Bucket front end reclusej Suspension - Brakes - Steering 2 02-27-2002 05:06 PM
