front fender 65 el camino - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2010, 09:21 PM
defilade's Avatar
2012
can someone talk me through removing front driver side fender?
thanks,
wil
Old 04-14-2010, 06:17 AM
deadbodyman's Avatar
Wiki Edits: 11
what are you having trouble with?
Old 04-14-2010, 07:48 AM
thanks,
wil
you have to cut the bolts or grind away the welds youse hamer and little chizzle it may leave a mark most old american cars were made like that it was fast and cheap hope i could help
Old 04-14-2010, 09:01 AM
dinger's Avatar
There are bolts behind the door, to the cowl under the hood, going up into the cowl under the fender where it meets the door, to the gravel shield, to the radiator support. Approx. a dozen. Most feel it's easier to remove the inner fender along with the fender, less bolts to remove. Get the bolts out, pop the fender out where it meets the door, start pulling, wiggling, slapping, shaking, kicking until it comes loose... Seriously, when you start pulling the fender away from the body, you should be able to trace any bolts left tightened by the movement or lack of movement of the fender. There may be some frozen/rusty bolts, give them a blast with some good rust breaker before you tackle the job. Good luck, ask away if you have more questions. I'm assuming the front bumper is off already, if not, remove it, it will make the job MUCH easier. Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 04-14-2010, 02:48 PM
defilade's Avatar
2012
fender
thank you sir
aligning hood gto_ron Body - Exterior 8 03-25-2009 06:22 PM
Want El Camino 60's-70's project. sixties Hotrodding Basics 2 01-11-2006 07:34 PM
el camino fenders amish Body - Exterior 1 05-16-2003 04:31 PM
Looking for some El Camino front clip parts jamiea1979 Interior 4 10-09-2002 12:59 PM
A tilt front end on a el camino Diblos5150 Engine 0 09-08-2002 01:35 PM
