Front Four Bar Angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2009, 06:24 PM
Last journal entry: Rear End Disassembly
I am in the process of tacking my front four bar to my frame that I created on my studebaker project. Since I went with such a large tire size, the front area of the frame is rather tall off the ground. This is using air ride as well. I currently have the frame 4" off the ground (ride height), and the bottom side of the front of the frame is 16" tall.
When I set my four bar up with the kit from Speedway, the mounts supplied will set the four bars at a 4 degree angle sloping towards the front of the car. This is with the frame mount welded underneath the frame rail.
What is the desired four bar angle at ride height (I assume 0 degrees). Is there a problem with doing otherwise?
Thanks!
Old 06-27-2009, 08:32 AM
Frisco's Avatar
Glad To Be Here
Thanks!
The angle of the 4-bars is not where you should be concerned. They should be parallel to each other.
It is the angle of the kingpins that you should be concerned with.(Caster angle)
This is adjusted by screwing the ends of the 4-bars in or out as needed to yield the correct angle. The angle for a straight axle should be in the range of 5-7 degrees towards the rear with the car at ride height. 0 degrees will not work. That 0 degree angle will yield wandering as well as shimmy and the steering will not "return to center".
Front Crossmember Angle 71gtx Suspension - Brakes - Steering 24 01-16-2009 12:44 AM
Chassis plans etc Jonesy_sa Hotrodding Basics 7 11-28-2008 07:10 PM
Pinion Angle? Again? oldskools10 Transmission - Rearend 7 01-27-2007 02:48 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
penion angle wolfemanbud Transmission - Rearend 2 10-04-2005 07:58 PM
