Front frame / Front crossmember blueprints - feedback needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2008, 06:41 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
frame material will be 2.5 x 2.5 by ??? wall (forget what it is i have outside, think its 1/8")
car will be getting a full cage with engine bay / trunk bars
car will be converted from strut to dual a arm, which includes new spindles and fabbed upper and lower control arms
the side view picture has a blow up of the gusset, the pink lines are double the diameter of the hole size to show spacing which i believe is correct
any questions / suggestions / insights / problems that you see ?
Name:	240 frame 1.jpg
ID:	32217   Click image for larger version
Name:	240 frame 2.jpg
Old 09-02-2008, 02:42 PM
Wiki Edits: 22
noone has any suggestions ? ?
Old 09-20-2008, 05:46 PM
Wiki Edits: 22
bumping just in case anyone has anything ...
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 08:42 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
frame crossmember johnnymopar Suspension - Brakes - Steering 7 05-29-2003 04:04 PM
front end unsetable, use off set upper shafts or bend frame what to do IHAVECHEVYPARTS Suspension - Brakes - Steering 4 11-16-2002 10:19 AM
Help!! T Bucket Frame Blueprints Barz51 Hotrodders' Lounge 7 11-06-2002 11:55 AM
