front grill moulding - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2010, 03:16 PM
hello all, i have a74 gmc pickup, my question is on my headlight bezels mine are all in one with the turn signal in it as well,,,,,,,,i have seen some trucks on the net with only the headlight in the bezel and the turn signal by itself,,,,,is mine the correct one for this year truck , or is it the other one i mentioned, any help would be greatful,,,,,,,,,,,thanks again always appreciated
Old 09-04-2010, 05:26 PM
ericnova72's Avatar
More for Less Racer
The bezels you have are for the 78-79 trucks. The bezel you should have if you want the stock look is smaller, does not include going around the turn signal, with a seperate turn signal lense/bezel. You can use what you have just fine, just isn't technically stock for that year.
Old 09-04-2010, 07:38 PM
headlight bezel
hey thanks nova,
thats too funny my insurance lists my truck as a 79 but the vin # in the cab list it as a 74 either way, i like it just fine,,,,,
Old 09-04-2010, 08:13 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
74-75-76---meets thin molding near grille
77-78--molding a bit wider-----still separate park/turn bezels if equipped.
79-80 (80 round lights)----wide lower grille/valance molding - about 3"
corvette front clip rhinz1966 Body - Exterior 12 01-11-2010 04:57 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Idler Arm help after front tire change 360Camaro Suspension - Brakes - Steering 1 12-28-2003 11:49 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
