Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Front marker lights turn off when headlights turn on
Old 02-10-2013, 01:50 PM
LATECH's Avatar
LATECH LATECH is offline
Front markers are working correctly now. They werent designed to be on when the headlights were on, but only when the headlight switch was turned to park lamps.
On the headlight switch, you can move a wire to achieve this . I will eclose a photo.
My 64 does the same thing...I am going to change it also.
Try jumpering these two connectors where the little spade is across the two terminals first to be sure it works.
ID:	71244   Click image for larger version
Fact is stranger than Fiction
