Front outer tie rod que? Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2012, 06:37 AM
Finishing up my must ll front end my tie rod seems to go up in my lower arm and I still have about 1/2, or about 3/4 inch before it touches my rubber boot. I have enough room for my cotter pin. Would this be o.k. Or should I try and impact my nut down?, thanks, Dana
Old 01-16-2012, 08:39 AM
delawarebill's Avatar
angle
i'm thinking the bevel of the male/female are not the same angles... meaning putting a 20° male into a 15° female fittng. it wouldn't seat... thinking out loud on this one..
Old 01-16-2012, 11:58 AM
Chopt 48's Avatar
Originally Posted by delawarebill
i'm thinking the bevel of the male/female are not the same angles... meaning putting a 20° male into a 15° female fitting. it wouldn't seat... thinking out loud on this one..
That sounds like what you may be running into. You might first want to check the taper on the hole and the taper on the stud to make sure that they match.
What changes did you make with the tie rod ends and spindles if any? I can measure the stud on one of my stock MII tie rod ends as far as length goes it that helps along with measuring the thickness of the stock I in the MII spindle. Pm or email me if that would help.
Old 01-16-2012, 12:44 PM
Tie rod
Sounds like your both right, wrong taper to match. It is the IFS kit (stage 1) from fat man. I do have plenty of room for installing my cotter( with small spacer to make it real nice fit) BUT would this be a good idea? I've thru all shipping pkg's away so don' want to send back. Also thinking about reaming the hole a little bit?Advise, thanks again, Dana
Old 01-16-2012, 02:50 PM
Chopt 48's Avatar
I'd just call Fatman and see what they say. I'd have the part number for the spindle and the tie rod end handy if they were available. It may be that the arm on their spindle is a bit thinner than the stock items.
Old 01-17-2012, 04:20 PM
Tie rod
Found out today my front tie rod is designed this way w/approx 3/4 in away from the boot. This keeps the steering from getting to far out of wack, better steering for the customer. (I guess I should read all instructions first) Thanks for the help, Dana
The Outer Limits Chevyjeepster Engine 3 12-14-2011 10:47 AM
Outer cam bearing 19nova69 Engine 8 05-23-2010 07:32 PM
outer limits on timing fredsnook Engine 8 12-26-2004 05:06 AM
what are the outer dimensions of a 426 mech-techie Hotrodders' Lounge 1 06-05-2002 02:06 PM
inner and outer tie rod difference stoke46 Suspension - Brakes - Steering 1 01-31-2002 07:35 AM
