Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 03-29-2008, 07:08 AM
powderbill powderbill is offline
Front Panhard Mounting Pros & Cons
I'm trying to decide on a technique for fabricating front panhard mounts for a solid dropped I beam axle with 4-bars and spring-over design.
Part of me says drill a hole for a mounting stud through the web of the axle. But, should I have any concerns at all about weakening the axle at that point?
A second option is to attach the panhard to the batwings in some fashion. But, this would appear to have some potential to place extra bending loads on the 4-bars. Is this something to be highly concerned about, or am I just obsessing?
In principle, it seems like one might be able to make some sort of attachment to the spring perch bolts, but I've not figured out yet how to make that geometry work out successfully.
Before I start drilling and cutting, I'd be interested in any advice or suggestions on ways this has been done successfully.
Old 03-29-2008, 07:20 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
re: Front Panhard Mounting Pros & Cons
See the LINK . This is a kit that Speedway sells. You could easily fabricate one yourself. One bracket is welded to the bottom of the frame rail (usually on the drivers side). The other bracket bolts to the "Batwings" that the four bars bolt to. The Panhard bar bolts between the two brackets.
Old 03-29-2008, 11:32 AM
Thank you for the helpful comments, Frisco. While a picture is sometimes worth a thousand words, in this case it was your explanation that was the most helpful. I'd seen the pic in the Speedway catalog of their setup, but at the resolution that was available, before reading your explanation of what went where, I was having trouble figuring out exactly what I was looking at and where it was supposed to attach!
Old 03-29-2008, 12:48 PM
RODDER18's Avatar
RODDER18 RODDER18 is offline
I have installed the speedway pan hard bar assembly, it comes with everything you need and is easy to install.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Front Panhard Mounting Pros & Cons"
6 pack pro's vs. con's jesse01 Engine 4 11-23-2005 08:46 AM
pros and cons of fuel pumps cobra513 Engine 7 07-22-2005 12:04 PM
Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps Jon Suspension - Brakes - Steering 0 10-12-2003 02:56 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 05:50 PM
gm front suspension in a 53 Studebaker wheel-7 Suspension - Brakes - Steering 1 08-15-2003 07:13 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
