front plug fouling - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2005, 01:15 PM
Knobie's Avatar
55_crush
front plug fouling
Both my front plugs are fouling. I have been told that due to aluminum heads, the cylinders closest to the waterpump tend to run cooler. Has anyone had a similar problem? I have tried various different plugs and finally tried iridium plugs which bought me more time out of the plugs.
Thx Ted
STAND ON IT!
Old 09-07-2005, 05:35 PM
Knobie's Avatar
55_crush
Nobody had this problem before?? Anyone have any ideas??
STAND ON IT!
Old 09-07-2005, 07:05 PM
coldknock's Avatar
What engine?
Larry
Old 09-08-2005, 06:57 AM
Knobie's Avatar
55_crush
It's a small block chevy.
Thx
STAND ON IT!
Old 09-08-2005, 07:38 AM
Knobie's Avatar
55_crush
Here is a bit more info:
I have been dealing with this issue for a couple of years now. The two front plugs are fouling. I have tried various different plugs, the motor runs great. If I run the car around town, the two front start to break down and miss. When I inspect them, they are very sooty. The rest of the plugs are a nice colour. Recently I replaced all the plugs for iridium (NGK). This bought me more time between replacement, but still have to change those #@&* front plugs. If I go on a highway run, the front plugs look as good as the rest of them and no break down. I was told that with aluminum heads, being close to the waterpump, run cooler which makes some sense to me. The motor is a stock bore 350 sbc, 11.3/1 compression, hydralic cam 244 / 253 deg @ .50 .533 lift, 700 CFM D/P If anyone has any ideas or has had a similar problem, let me know. If you need more info, please ask.
Thanks!
Ted
STAND ON IT!
Old 09-08-2005, 10:09 AM
I would suspect plug wires or the dist. cap first--sounds like the front plugs aren't getting full spark. Lower RPM town driving would increase the prob. You may want to check for air leaks at rear areas of intake and rear of carb.
Old 09-08-2005, 10:15 AM
johnsongrass1's Avatar
Race it, Don't rice it!
That's a load of bull...
Are the plugs fouled with gas or fouled with oil or what? got a picture?
Old 09-08-2005, 11:01 AM
Knobie's Avatar
55_crush
sorry no picture. The appearance of the plug is sooty except the end of the electrode which is a tiny white "spot" The buildup appears to be of a rich situation which can be easily wiped off. It is not a oil problem. When the plugs are changed, the motor runs perfect.
STAND ON IT!
Old 11-30-2005, 04:23 PM
Knobie's Avatar
55_crush
I thought that I should bump this as the situation is a concern to me and it is being lost in the "archives"
STAND ON IT!
Old 11-30-2005, 04:59 PM
steve t's Avatar
ex biker, now hotrodder
if that was true, everybody would have a problem, run a compressure check,change spark-wires
Old 11-30-2005, 05:06 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
For some reason or other those two cylinders are running rich and your gassing your plugs. Thats what it sounds like anyway.
Old 11-30-2005, 05:41 PM
Bumpstick's Avatar
Hammer and a torch
What temp thermostat...?
Old 11-30-2005, 06:14 PM
what intake and has it every been replaced? It could be an uneven distribution from a poorly cast intake or obstruction...if it's fuel injected could have leaking injectors. We need alot more information....it's not because of aluminum heads. It sounds like you are getting a different A/F ratio on these two cylinders, but without knowing some more about the setup it a wild guess.
Old 11-30-2005, 07:08 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Try reducing the gap on the front two plugs from 45 to say 32, and drive it for awhile and see if the problem declines..
If so, get a better (hotter) coil, and better Wires.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 11-30-2005, 09:45 PM
Siggy_Freud's Avatar
If you think about it, the front two cylinders should be the last to recieve the water due to its flow route (in through the bottom, out through the top). By that time the water has run through the entire engine thus soaking up heat to be radiated outwards through the . . . radiator. The truth is there should be very little variance of the cylinder head temperatures as you go from to back. If you think about it more, the back driver side of the engine should be the hottest as you have two cylinders next to eachother firing one right after the other.
Have you changed wires or checked them?
Bringing history and technology together.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Spark Plug brands question Francis Engine 65 07-15-2008 01:01 AM
spark plug fouling mitmaks Engine 1 04-04-2005 09:05 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 05:42 AM
#2 plug fouling Walker Engine 13 09-01-2003 10:13 PM
