Front pump seal 700r4
With this repair, I was wondering if I can jack the front of the car up 2 feet and just drop the tranny one foot ( with a tranny jack )and replace the pump seal? If I take them bolts off will a ton of fluid and or parts fall out?
Or do I have to remove the entire tranny and stand it on end? What is the easiest way to fix in my garage? Thanks again |
did you see my response to your other post about the same leak problem? trying to do it as you describe will result in many problems.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Actually I was trying to ask a different question. Thanks for the help. I guess you already answer with this reply. I was thinking on just changing the gasket or seal on the front pump....( and not removing the pump )so you are saying there is going to be a little more involved even with just changing the seal.
My questioning this soo much is because I do not want to start something I can`t finish AND if it this is gonna be a pain in the *** for a hobby mechanic I`ll just toss in a new turbo 350 and have a stronger tranny. |
