Front radiator cowl
I am working on a 31 Tudor and I am going to keep it full fenderd. I plan on putting a 32 radiator cowl and the V8 headlight bar. My question is other than the different cowl will the same hood fit? Also, can I use the 32 headlight bar with the 31 fenders? Any hints from anyone who has done this would be helpful.
Thanks, Chums |
You can use a 32 radiator shell and your hood will still fit...you can also use the 32 light bar on the A model. By the way...a cowl is the portion of the car between the fire wall and the windshield and doors.
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| 32 ford frame width at front axle centerline | Dirty Steve | Hotrodding Basics | 4 | 05-15-2006 07:40 AM |
| Chevy truck Tilt front End! | Onestophotrodshop | Body - Exterior | 0 | 12-01-2005 11:26 AM |
| Idler Arm help after front tire change | 360Camaro | Suspension - Brakes - Steering | 1 | 12-28-2003 11:49 AM |
| Removing fenders? | Jag Daddy | Body - Exterior | 3 | 11-26-2003 04:42 AM |
