Front and Rear Axle issue
I ran into a small problem today which i hadn't really paid much attention too. I measured my lug spacing on the front and rear axles and found they are different. My front lug spacing is 5 lug on 5.5" spacing, and my rear axles are 5 lug on 5.0" spacing. I am not sure what to do here, should i just find rims that will fit and call it good, or should i replace the front or rear? What would you do in this situation? The rear ford 9" is off of a 77 ford truck and the front axles are from 1947.
ford truck rear
Most ford truck rears were 5 X 5.5 ,the same as the 48 and earlier rear. There were very few ford pickups made with pass size bolt patern 5 X 4.5, they were building a light duty pickup and tried to get pass car ride for people that ran empty most of the time. With emission standards that went by GVW it was cheaper to build the F150 with heavier springs shocks tires and not have to do the emission add ons You should be able to find a pickup rear end to bolt in with the patern you need. ..5 X 5 was used on biger ford, linc, merc, cars.
Go to Early Wheel or email Jason at jason@bearmetalkustoms.com for all your wheel needs. I have purchased from Jason several times and the turn around is excellent. Quality is excellent. Good guy to deal with. Very fair pricing.
He may even have the wheels you need with the centers having both lug patterns so that the wheels will fit on either end. |
Thanks for the link frisco........Looks like i will be using a wheel adapter on the rear axle. This will allow me to go from a 5 on 5 to a 5 on 5.5......
I run a set of chrome smoothies with a 4.5 and 4.75 pattern on each wheel. Ford 9 inch rear and firebird front clip.
Chrome 15x8's with 5x5 and 5x5.5 I run 56 chevy caps on mine but wheel vintiques has a bunch of ford caps to choose from. Call them to ask if they will fit the smoothie wheels. Here
Thanks guys. |
| Rant about aftermarket sheetmetal | cyclopsblown34 | Body - Exterior | 27 | 01-28-2010 10:14 AM |
| corvette front clip | rhinz1966 | Body - Exterior | 12 | 01-11-2010 04:57 PM |
| trunk lid problems | gto_ron | Body - Exterior | 35 | 12-20-2009 08:09 PM |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Hoods not shuting all the way | 74_Chevrolet | Body - Exterior | 5 | 09-01-2005 07:10 PM |
