You only need the main bolt for the pick-up on rear sump pans. He has one of those already. The front sump pick-up doesn't require one as it doesn't span the length of the engine.
I see the flat spot on the timing cover where a hole could be. Any reason I cannot drill a hole accepting the dip stick holder and use the same timing cover?
Just get yourself a tube and stick from FORD and you should be OK.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
