Front and rear oil sump on Ford 351W
I just noticed the 351W I bought, which needs to be re-built, has a rear sump oil pickup. My project car requires a front sump.
At re-build time, I think this is an easy fix, correct? thx in advance, r
Yes. You will need a front sump pan and pickup.
thank you
Thank you. I thought over the years on the this board it was true. r
I see a flat spot on the timing cover
I see the flat spot on the timing cover where a hole could be. Any reason I cannot drill a hole accepting the dip stick holder and use the same timing cover?
thx, r |
Just get yourself a tube and stick from FORD and you should be OK.
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| body parts fitting | anyoldchevy | Body - Exterior | 10 | 02-20-2005 09:20 AM |
| Door Alignment | Ron M | Body - Exterior | 2 | 08-21-2004 01:43 AM |
| Removing fenders? | Jag Daddy | Body - Exterior | 3 | 11-26-2003 04:42 AM |
| body panel alignment | gmonkey | Body - Exterior | 5 | 09-01-2003 06:50 PM |
