front or rear steer - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2006, 10:19 AM
front or rear steer
I've seen alot reference to front or rear steer, when doing front end modifications. What is the difference as far as which is better for what appication?
Old 11-19-2006, 12:00 PM
woodz428's Avatar
Troll Hunter
Usually thar term is used to describe 2 different GM front clips that used to be common to use. A simple rule of thumb I used was that the more the front end comes to a point the more you need a rear steer. A front steer application in many early( almost ALL) cars requires a lot of modification to the area in front of the suspension to eliminate interference with the sheet metal. When you start doing the more "boxy" style later cars it is probably no difference which you use.
Old 11-20-2006, 01:10 AM
aka Duke of URL
Also used in reference to where the steering arms are located on the spindle. This is a major factor in steering rack conversions. For example, the MUST II system is FRONT STEER whereas the TAURUS system is REAR STEER.
Camaro Front Suspension & Rear end Chevy535 Suspension - Brakes - Steering 1 07-19-2006 12:50 PM
Sealing front and rear window channel question flipp121 Body - Exterior 5 02-20-2006 10:14 PM
Front to Rear Differential swap adryan16 Transmission - Rearend 2 07-21-2005 09:36 AM
Front and rear oil sump on Ford 351W RAW Engine 8 06-05-2005 03:30 AM
gear ratios in a 4x4 front vs. rear.... crazy larry General Rodding Tech 3 04-15-2005 07:30 PM
