Hotrodders Bulletin Board
#1
Front/Rear Wheel Offset
This question is for all you suspension gurus out there. Should the front and rear wheels be in the same track for street use, or should one of the axles have a wider track than the other? Thanks for your help.
#2
re: Front/Rear Wheel Offset
Do not claim to be a guru....... But Most street rods have a wider track on the rear....due to larger ( wider rims and tires ). If you buy a new Chassis from TCI.......the front and the rear will have the same width.......before the wheels and tires are installed...... Deuce... |
#3
It matters very little. Most of GM and Ford's cars came with a narrower track in the rear to help with aerodynamics. It wasn't much, like an inch or so.
I say, use your artistic eye. Set it where you want it. The most you can play with it is about an inch either way depending on the car, so you won't damage anything. |
#4
Gee, Why dose a dragster have such a wide front and narrow rear? Maybe it makes it go straight?
Most mfg's build cars with a slightly narrow rear to assist in straight line stability. Hotrodders do what ever looks cool. You do it your way. |
Back to top |
Similar Threads for: "Front/Rear Wheel Offset"
| Front/rear wheel weight ratio? | staleg | General Rodding Tech | 9 | 12-16-2005 03:47 AM |
| wheel offset question | 53LEDSLED | Suspension - Brakes - Steering | 3 | 09-25-2005 01:03 AM |
| Help me understand wheel offset! | frankenvette | Hotrodders' Lounge | 6 | 07-09-2004 09:30 PM |
| Bleeding Wheel cylinder on a 91 corolla | ramvrao | Suspension - Brakes - Steering | 1 | 03-20-2003 03:38 PM |
| reverse offset wheel spacing | danfan70 | Suspension - Brakes - Steering | 2 | 04-02-2002 03:23 PM |
