Front seats in 67 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2007, 06:38 AM
I'm thinking of upgrading the front buckets in my 67 Camaro. I'm looking for more side support and adjustability. Are there any later model Camaro seats that will more or less bolt in? Any suggestions for good aftermarket seats that don't cost $800 or more a piece?
Old 08-10-2007, 10:34 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Your original seats should be attached to mounting brackets that are attached to the floor. If you take the seat off the mounting bracket, most GM buckets, and a lot of aftermarket seats, will bolt right up to the original mounting brackets. All you have to worry about then is if the seat is high enough for you to see out of the windshield. If the seat is too low, shim up the seat and you're in business. Lowering the seat is trickier.
Old 08-10-2007, 10:52 AM
302 Z28's Avatar
Just don't install any high back buckets in that Camaro, they look stupid.
Vince
Old 08-10-2007, 11:37 AM
front seats
Thanks for the input, I'll see what's available in the later model F body's. I agree with the high back bucket remark. They just don't look right in the early Camaro's.
Old 10-02-2007, 06:29 PM
GTS GTS is offline
seat choices
Hi Earn,
I was nearly in the same situation, finding a good supportive classic seat that looked not like the fast and furious.Until I did something about it...Try our website ***************.com, maybe something you like, also we will come to SEMA with a new seat for the TRANS AM generation....
regards Stefan
Last edited by DanTwoLakes; 10-03-2007 at 01:48 AM. Reason: Advertising. Please see: commercial posting guidelines.
Old 10-03-2007, 01:45 AM
Wiki Edits: 22
Your post violates the rules of this forum regarding commercial advertising. You can put your URL for your website in your user contact page and refer people to it. Please check over the rules and try your post again.
Dan
1980 Camaro Replacing both Front end finders, before I start help needed... Juicer Body - Exterior 8 01-14-2008 06:48 PM
camaro front sub waynedawg Suspension - Brakes - Steering 2 06-16-2004 12:03 AM
67 camaro rearend 72 Z28 Transmission - Rearend 2 02-09-2004 05:53 PM
idler arm for 67 camaro bowtiedragracing Suspension - Brakes - Steering 3 09-17-2003 06:45 PM
Bolt on front spindles for a 67 camaro for5 on 5 LAZYB Hotrodders' Lounge 2 04-25-2002 07:29 AM
