Front shock upper mount
I installed a c4 corvette suspension in my 39 packard i am wondering how to build my upper shock mount so it works right i have stock lower mount and front leaf spring i am not going to use coil overs right now is there a certain degree the shock should be set at di i build it with shock fully exstended and suspension hanging or at ride height thanks for any info
You need to make the shock mounts with the suspension at ride height for sure.
Measure the total travel of the shock and make the mount so there is about 2/3 of the total travel available for compression (bump) travel and 1/3 for extension (droop). I build the mounts as short as possible to reduce the leverage on the bracket, but not so short that you can't move the upper control arm for alignment. That will determine the shock angle. In the last C4 suspension I put in I built mounts that come over the top of the control arm so A-arm clearance wasn't an issue. That was a bit more involved than coming up from under the upper control arm on the outside face, but for this application I was using long coil-overs to gain travel, so it was necessary. Regards, Andy |
Thanks for all the info that will help me out with my shock mou
nt design
| upper rear shock mount bar question | andrewakessler | Suspension - Brakes - Steering | 6 | 11-15-2012 08:01 PM |
| front top shock mount 59 chevy truck | jhatch43 | Suspension - Brakes - Steering | 1 | 02-10-2012 11:33 AM |
| upper shock mount relocation | dboyett81 | Suspension - Brakes - Steering | 0 | 04-12-2011 09:23 PM |
| 59 chevy apache front upper shock mount | sport41 | Introduce Yourself | 1 | 04-17-2010 04:52 PM |
| 59 chevy apache front upper shock mount | sport41 | Suspension - Brakes - Steering | 1 | 04-17-2010 04:51 PM |
