Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Front shocks 51 Styleline
Old 06-29-2012, 03:13 PM
brian720 brian720 is offline
Lower shock mounts
These apparently fail frequently as per 2 parts houses. One supplier told me most buyers get 3-4 at a time. The obvious solution to me was to build a better mouse trap. I'm sure I am not the first person to figure this out. I had the broken tab tack welded in place and then had them add a reinforcing piece of steel in the bottom side of the mounting bracket. That necessitated driving the small mounting stud out of the lower suspension arm. I replaced that with a 1" x 3/8" bolt and used a compression nut. The fit was perfect, and there is plenty of room to use a wrench on the bolt head. I don't think these mounts will fail. The car rides fine and the shocks mount just as before. Spraying some PB Blaster on the studs and letting it sit over night made them very easy to tap out. Put a nut flush to the edge of the stud if you don't want to ruin it in the removal process. A few light taps with a heavy ball pean hammer took them both out.
Name:	frt shock mount 1.JPG
ID:	66440   Click image for larger version
Name:	welded mount top.JPG
ID:	66441   Click image for larger version
Name:	welded mnt. 2.JPG
ID:	66442   Click image for larger version
Name:	welded mnt and bolt.JPG
