Front Spindle Repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2005, 05:02 AM
I have some front spindles off a 54 Chevy truck that need to be repaired. There are some grooves at the bearing areas. I cannot find any place that sell new spindles. Does anybody know if they can be "welded up, then ground down" without warping the spindle?
Thanks in advance.
Old 10-14-2005, 08:49 AM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
Surley there is. We used to have a guy come in,called axle doctor,or something along that name,where I worked at. When a Tractor or Trailer dropped a bearing,it would gouge the spindle. The guy would come out,cut the old spindle off the axle,TIG a new one on it,take crockus cloth and clean it up real well.I would see if there is someone local who may be able to do that for you.
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
mustang front clip swap 2wld4u Body - Exterior 5 11-02-2003 10:07 PM
GM Front Diff. Reliability For Full Time Use. M&M CUSTOM Transmission - Rearend 4 10-31-2003 06:36 PM
Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps Jon Suspension - Brakes - Steering 0 10-12-2003 04:56 PM
repair of front spoiler moparbandit Body - Exterior 3 06-02-2003 09:54 PM
