front spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2011, 11:38 AM
front spring
The crossover spring on my 36 pickup front axle has six leaves. is this enough to support a 350 engine plus accessories? I think it needs more leaves.
Old 05-31-2011, 10:57 PM
Curmudgeon29's Avatar
Now that wasn't so easy!
That should be plenty! Set the engine in there and see how much it settles
Old 05-31-2011, 11:05 PM
Wiki Edits: 27
bad roads ?
The springs were designed for bad roads and hauling a load. If the truck is just going to be a cruiser you won't need as much spring. and you probably dont want "it to ride like a truck"
Old 06-02-2011, 12:46 PM
front spring
OK, thanks, I still have to replace all the bushings in the whole axle assy, just trying to get all my ducks in a row before I start.
Help! Front spring perches lamonicas Suspension - Brakes - Steering 3 11-12-2010 06:11 AM
front spring for a 67 firebird bbc 454 71javelin Suspension - Brakes - Steering 1 09-02-2008 07:03 PM
Lowered front spring 36henry Suspension - Brakes - Steering 1 03-13-2007 01:17 PM
Front spring mount. Pepsi Suspension - Brakes - Steering 9 10-16-2006 01:19 PM
Front spring lowering, CUT THEM! 39chevy Suspension - Brakes - Steering 5 10-16-2004 09:42 PM
