front spring help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2012, 02:02 PM
front spring help
I have a 33 plymouth with a mustang II front end. I want to go from 10 inch springs to 8 inch and dont know what weight spring would be best. The car does have a high horespower big block 440
Old 02-19-2012, 03:08 PM
Last journal entry: update
If the rate is too soft, they'll act like drag-racing springs. Going stiffer can help handling. You'll probably want at least 250 lb/in, and possibly as much as twice that.
Old 02-19-2012, 08:04 PM
Last journal entry: Finally some floor!
Hey 33 ply, I like your ride! I would like to help you on your spring question, but I have two strikes against it. 1: My 33 Ply is a four door and, 2 mine has S-10 front end. But perhaps we will run across other similarities? Bob
front spring mhernandez Suspension - Brakes - Steering 3 06-02-2011 11:46 AM
Front Coil Spring help 1969ChevelleGuy Suspension - Brakes - Steering 10 04-22-2011 05:08 AM
front spring for a 67 firebird bbc 454 71javelin Suspension - Brakes - Steering 1 09-02-2008 06:03 PM
front spring removal bct Suspension - Brakes - Steering 5 09-12-2006 09:16 PM
Front spring lowering, CUT THEM! 39chevy Suspension - Brakes - Steering 5 10-16-2004 08:42 PM
