front springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2012, 08:56 PM
front springs
I am attempting to set up my first dropped axel suspension.I am wondering ,Can I use the stock front leaf spring on a dropped axel?
Old 04-30-2012, 09:12 PM
Sure you can, it simply won't be as low as it can be. There are all kinds of springs on the market that will lower it a lot more AND give a better ride. You can also have a reversed eye main spring made that will lower it. In the old days, you took that main spring and beat the living crap out of it over a anvil until it curved the other way making a reverse eye spring.
Old 04-30-2012, 10:50 PM
Wiki Edits: 27
reverse eye
I used my Harbor freight pipe bender, chalk marked the floor and gradually worked the spring in the press along the length until it flattened then kept going until it matched the chalk.
Old 05-03-2012, 08:22 PM
front springs
Thanks for the advice on useing stock front spring. Your comments help
what front springs 33 plymouth 5 window Suspension - Brakes - Steering 0 02-20-2012 07:47 AM
81 c10 front coil springs swap for s-10 springs campracing Suspension - Brakes - Steering 3 10-05-2009 05:51 PM
Front springs DoubleVision Suspension - Brakes - Steering 3 01-20-2008 02:37 PM
front springs 49dream Suspension - Brakes - Steering 4 08-28-2006 11:26 AM
front springs mitch 36 Suspension - Brakes - Steering 2 04-05-2006 12:31 PM
