-   -   front springs (http://www.hotrodders.com/forum/front-springs-86110.html)
mitch 36 04-04-2006 09:12 PM
front springs
anybody got any input on what springs i should use for must.II suspension under my 36 chev pick up ? im running a 250 six with a turbo 350. i had pinto v-6 springs with a half coil cut when the 350 was in it .it rode okay but a little stiff.the six is in the stock location.its a fat man crossmember with heidts tubular arms.also if anyones interested, i welded a second 2 inch box crossmember behind the fat man cross to help take the thrust load of the lower arms.it looks to be a better idea than those goofy little gussets. thanks for your input.
Centerline 04-05-2006 08:55 AM
You need Mustang II 4 cyl (without air conditioning) springs for that application. Something with around a 310-320 spring rate. Go to Eaton Springs and check their recommendations.
mitch 36 04-05-2006 11:31 AM
thanks centerline. thats kinda what i figured but i thought id ask the majority.
