front springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 09:12 PM
front springs
anybody got any input on what springs i should use for must.II suspension under my 36 chev pick up ? im running a 250 six with a turbo 350. i had pinto v-6 springs with a half coil cut when the 350 was in it .it rode okay but a little stiff.the six is in the stock location.its a fat man crossmember with heidts tubular arms.also if anyones interested, i welded a second 2 inch box crossmember behind the fat man cross to help take the thrust load of the lower arms.it looks to be a better idea than those goofy little gussets. thanks for your input.
Old 04-05-2006, 08:55 AM
Wiki Edits: 49
You need Mustang II 4 cyl (without air conditioning) springs for that application. Something with around a 310-320 spring rate. Go to Eaton Springs and check their recommendations.
Old 04-05-2006, 11:31 AM
thanks centerline. thats kinda what i figured but i thought id ask the majority.
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Please all read... want to start a BIG project knowldgeisfatal Suspension - Brakes - Steering 58 06-29-2005 07:55 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
front coil springs 92 power ranger Hotrodders' Lounge 0 07-12-2003 07:55 PM
