front springs for my Nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2003, 07:51 PM
Novaman78's Avatar
Kill It & Grill It
Last journal entry: New door panels
I have a 78 Nova and i need new springs for the front end. Does anyone know what car can i get them off of and where from?
Old 10-26-2003, 07:56 PM
poncho62's Avatar
Wiki Edits: 5
Best to buy new springs......the junkyard ones that you buy are liable to be as weak as the old ones.
Old 10-26-2003, 08:08 PM
Novaman78's Avatar
Kill It & Grill It
ok thanks. the ones on here now are so bad my front tires rub on the inside of my fender wells and i only have a inline 6 with 14 inch rims.
Old 10-26-2003, 10:36 PM
www.coilsprings.com
www.eatonspring.com
or your local Moog dealer
Old 10-27-2003, 06:15 AM
Novaman78's Avatar
Kill It & Grill It
Ok thanks guys ill check thoose out.
Old 10-27-2003, 01:08 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
The X-body and the F-body share the same front subframe assembly. Which means there is a while plethora of parts available for ya
Just cross reference to make sure they will fit if you are going with anything other than OEM replacements!
Old 10-27-2003, 09:35 PM
Novaman78's Avatar
Kill It & Grill It
Ok thanks 78novaman there are a lot of camaros and firebirds around here tha are junked so i will check them out. I have a nother question if i got new springs dew i need new shocks too? i think mine has shocks and springs up front ... i will get back and let ya know soon
Old 10-28-2003, 12:55 PM
78novaman's Avatar
Most likely if you're springs are shot, then your shocks are history. The front suspention is a double A-frame setup, and it should be the same as any 2nd generation camaro/firebird. Also, I don't really recommened getting used springs, you're most likely going to end up with the same problem you have now, just becuase the springs are old and have been sitting around for far too long.
Also, is your nova a 2dr/4dr/custom/RS/hatchback? I belive the hatchback RS model had different springs then the regular granny models. BTW, mine is a 2dr Nova Custom(chrome package and 3 lens tailights instead of 2 lens ones).
Old 10-28-2003, 05:46 PM
Novaman78's Avatar
Kill It & Grill It
I think mine is a coustom because around the windows and the fender wells have chrome pieces around the edges. I havent found anywhere tha it says nova coustom but i think it is. There is a guy i know who has a 76 and has nova coustom emblems on his but he doesn't have any chrome peices just the 3 lense tailights.
Old 10-28-2003, 08:39 PM
78novaman's Avatar
here's a breakdown for ya:
3 tailight lenses: Nova custom
2 tailight lenses: All other models
I have a shop manual, so if you PM me your VIN# I can tell you exactly what you have.
