front straight axle on 32 ford model b truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2009, 11:14 PM
so im f-ing lost now....im a 06 grad from wyotech 22 years old.....need some help... im pretty comfertible on all aspects of my build exept for my chassis... im just looking for some ideas on my straight axle... i want a 3-4" drop. but what spindle do i use that will fit right on to my axle. not going to worry about anything else tell i get the front end finished.
Old 01-28-2009, 11:17 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
What kind of axle is it? What kind of vehicle?
Old 01-28-2009, 11:22 PM
its a 32 model b ford pick up... i have the original axle all is there for the most part. but ill probably buy a 4" like a Super Bell Drop Axle thats the brand just one i found on the net
Old 01-28-2009, 11:24 PM
A 1932 Ford pickup uses the same front suspension as the 1932 Ford cars. Most rodders use a 4 inch dropped axle. That is what I use. Chrome optional Most rodders use the 1937 to 1948 Ford car spindle also.
Both my 32 roadster and my 32 3W ... have a 4 inch dropped axle and a custom front spring.
Old 01-28-2009, 11:29 PM
ok so the picture of your front end. what spindle are you useing i want it alot like that but i beam drilled.. the chassis on this i want perfect no cut corners. im building a traditional rod with grade a chassis
Old 01-28-2009, 11:56 PM
I have 42 Ford spindles. The ones with a square back.
I prefer the round tube front axle
Easier to keep clean and shiny with the chrome on it.
than a drilled I beam
Old 01-29-2009, 12:00 AM
ya true but whats a little TLC going to hurt me im dumping all my money into it so i figured ill enjoy cleaning it. jk but thank you im sure ill have more ? latter on so ill appriciate the help.
split straight front axle with rack and pinion dmcurry22 Suspension - Brakes - Steering 15 01-09-2009 12:15 AM
48 ford truck w/T model front axle tripp68 Suspension - Brakes - Steering 13 01-02-2008 07:36 PM
Help identifying I-beam axle in 32 Ford heyjude076 Suspension - Brakes - Steering 1 10-11-2006 08:43 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
64 Ford Truck axle in a 34 Pick up??? teched Suspension - Brakes - Steering 1 12-23-2004 03:00 PM
